Power steering woes (video)
#21
#22
I really can't say what issue I had but after about 5 minutes of unsuccessfully messing with it while laying under neath it with my brother supporting it from above he says "I think we can maneuver it out from the top" it took about a minute to get it out from above. just be ready because it is pretty heavy for being in an awkward location!
I would imagine if you remove the bracket that the 2 bolts secure to at the bottom it will probably come out but I left that bolted in place.
#23
http://cgi.ebay.com/ebaymotors/OEM-L...Q5fAccessories
and you probably won't find a much better price than this!
#24
This item is blocked from canadian buyers....
Just thought about something concerning my truck. Last week, I took off 1/2 an inch from the ends of the rubber power steering hoses and clamped them in place with new clamps hoping it would stop it from leaking. Topped off ps reservoir with atf and bled the system. But since I did it I experience more bumpsteer. What can cause that?
#25
as for your question I have no idea, I don't even know what "bumpsteer" is!
#26
#27
I knew I had seen a video somewhere of someone removing the box. Granted, theirs is on a TDI, and they have a lift, but they do make it look easy!
http://www.youtube.com/watch?v=b7y1d...eature=related (about 6 minutes into the video)
#28
#29
on
I'm going to get the A1 Cardone reman. for $369.00 will let you know how it works out when it is installed. Tried to get it local at Carquest and Napa but both said the reman. sources are out of them. So I have to get it online. Wish me luck... 36k - 3 year warranty. Will let you know if I have any problems with the supplier. Never used them before... Checked the A1 Cardone website and part #s match up.
http://www.landrparts.com/catalog/?N...654+4294952323
I won't be doing it myself. Will take it to the shop and have them do it, as well as all the power steering hoses while they're in there. Getting that kit from AB as well as the steering ball joint kit to have them do too.
http://www.roverparts.com/Parts/9397D.cfm
http://www.roverparts.com/Parts/9375D.cfm
So steering system will get some needed attention in a couple weeks when I get back from Hawaii. Hopefully the steering box won't blow out on me on my way to Denver airport tomorrow morning! But with the luck I've had this summer I wouldn't doubt it...
jycsalas
04-17-2009 02:21 AM
