Power Window Regulator Snap-In Rollers are here.
Old Jun 2, 2011 | 04:06 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Default Power Window Regulator Snap-In Rollers are here.
Don't waste your money purchasing a new window regulator just because one of the rollers broke. Here is a simple cheap solution that will keep them windows working. Replacement Snap-In rollers are made of strong flexible plastic that can withstand the abuse. Just simply remove the old roller debris and Snap-In this replacement roller. Contact me for more details and ordering. Get Two Snap-In Rollers for $4.00. Also have OEM solid replica rollers which require removal of the stud. The solid replica rollers come complete with new stud hardware. Get two solid replica rollers with two new studs for $5.00. Contact me for details.
https://landroverforums.com/forum/me...p-rollers-493/
Old Jun 2, 2011 | 09:49 PM
CUpgt's Avatar
Hard nylon washers from Lowes work perfectly, just find the ones that are the right size and pop two on to make it thick enough. A pack of 4 cost me .76 cents. There is a write up in the tech section on discoweb.org
Old Jun 3, 2011 | 05:23 AM
LRD2&ME's Avatar
Thats nice, these work even better. Cast directly from the OEM part and designed to be used without modification to the stud. Some people do not have the availability of grinding the studs off. This roller simply utilizes the original stud and easily snaps in place.
Old Jun 3, 2011 | 08:10 AM
vegas99d1's Avatar
Are you making these rollers? What material is it made out of? How long have they been in constant use? I'm just curious as to how long they will last as they are "snap in" and the center hole will wear and get bigger with use and may "snap out"???
Old Jun 3, 2011 | 08:30 AM
LRD2&ME's Avatar
Durable, strong, flexible plastic which can withstand the abuse. This design allows for compression and flexibility. Of course they will wear, everything does. It is simple just Snap-In the replacement.
LRD2&ME
16
Mar 28, 2012 04:15 AM
calebbo
Mar 24, 2012 01:14 PM
LRD2&ME
Jul 6, 2011 12:35 PM
LRD2&ME
Jun 9, 2011 11:01 AM
LRD2&ME
Jun 2, 2011 03:54 PM
