problems getting started
Old Sep 25, 2011 | 10:03 AM
nahtanoj's Avatar
it kinda sounds like you pissed off your spider alarm.
Old Sep 25, 2011 | 03:00 PM
Danny Lee 97 Disco's Avatar
just installed an extra set of 12 volt outlets. ran the power direct from the battery, grounded it to the frame
Did you put a fuse in the new circuit? If not, you may regre that modification if you short it out, battery could explode!
One thing that can also make you think you have a starter problem is a corroded ground connection from your starter to the frame. That is a common problem on these beasts but can be easily resolved.
If you have not eyeballed it yourself, you really should do so!
Old Sep 25, 2011 | 06:27 PM
x2 on the fuse. No circuit should be set up without a reasonable fuse, I have seen too many truck, cars, ATVs, boats burned up because of "added wiring".
Old Sep 26, 2011 | 02:56 PM
qdriskell's Avatar
5th Gear
Used the color of the wires to find the starter solenoid relay, it was not where it was suppose to be, thank you very much. However, the problem is intermittent. Removed the starter relay, examined it for damage, replaced it, and the truck started. I don't know how I am going to trace such a problem. I am afraid to drive because I don't know if the truck will start once it's stopped. While looking for the problem I noticed some moisture in the area of the relay's, passenger's side of the vehicle. Could water be causing the problem???
jwb
Jul 13, 2007 01:58 PM
Darover
Feb 20, 2007 07:16 PM
BigDawg32
Dec 20, 2006 10:50 PM
Fishcamper
Jul 15, 2006 11:16 PM
opus13
May 13, 2006 05:07 AM
