pros and cons
its simple in design, easy to work on, CDL lever from the factory here is your transfer case
1996-1999 Discovery I Transfer Case - Automatic (Professionally Rebuilt)
on
I personally think that you would be better off throwing a SBC in there instead of 'trying' to build up the 4.0. A lot cheaper in the long run. Others may disagree, but you have to do the math yourself. Download the RAVE and read up. They are not difficult, just special.
The easiest way to get a little more power is to go get a 4.6L rover v8 out of a GEMS P38 Range Rover. It's still not going to be very fast though.
