PS Pump
Old Feb 7, 2020 | 08:07 AM
WaltNYC's Avatar
Default PS Pump
Before I put this on the truck I wanted to get the collective opinion from around here. I'm somewhat concerned with the sounds this unit is making when I turn the spindle. It is as if there is some 'play' inside the pump.
Is this a normal sound? (may need to turn the sound on your computer way up to hear)
Old Feb 7, 2020 | 10:59 PM
XCELLER8's Avatar
I think it's ok Walt............iirc mine was about the same, as long as there is no play in the bearing it should be fine
Old Feb 8, 2020 | 09:09 PM
jimvw57's Avatar
probably won't make a sound once it has fluid in it
Old Feb 10, 2020 | 07:10 AM
WaltNYC's Avatar
Thanks fellas.... The bearing is as it should be, no play. The sounds seem to be coming from the internals.
I never knew what was inside until I checked out the magic of youtube. I suspect those little fins that act like an impeller are making the noise. I learn something new every day.
Skip to the 2:00 minute mark to get a look at them.
bennycisco
Jan 21, 2013 07:40 AM
cipher982
Jan 11, 2013 12:44 AM
antichrist
Apr 26, 2011 02:00 PM
hilltoppersx
Oct 15, 2009 12:48 PM
bowtiecb
Jun 24, 2009 08:48 PM
