Question about Low Range and Abruptness of Shifts
Old Jul 19, 2012 | 01:47 AM
BD_LR4's Avatar
Default Question about Low Range and Abruptness of Shifts
I've been working on getting my Disco ('97 with AT) ready for some off-road use, and have occasionally put it in low range to keep the shifter working smoothly. I'll drive around for a few minutes also, just to ensure everything functions correctly. What I have noticed, since I bought the vehicle, is that the shifts are very abrupt ONLY when in low. Is this normal? There is no noise, but it feels like there is a big pause, then a big momentum push forward as the next gear is selected.
Does this seem like a potential transmission issue? Or a TCase problem? The shifting appears to be fine when in high and does not matter whether diff is locked or not.
Any insight would be appreciated. I am going to be changing the T-Case Gear Oil along with other fluids.
Old Jul 19, 2012 | 06:45 AM
Most likely normal and you are not used to it.
Have you done my major service list posted in the top of this section, it is a good guide towards getting your tuck current .
Old Jul 19, 2012 | 08:17 AM
fishEH's Avatar
Sounds normal. There's a lot of torque in low range that can make the truck feel jumpy.
Don't drive around on pavement with the diff locked.
Buy 7qts of gear oil and do the TC and both diffs at the same time.
Fishman
May 20, 2014 10:28 PM
bcolins
Dec 9, 2013 03:56 AM
elrocha69
Dec 14, 2007 05:42 PM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
freeland02
Freelander
Sep 27, 2007 10:15 PM
