Question on Wheel Hub Locking Nut
Old Dec 8, 2021 | 09:37 AM
DiscoNewbe's Avatar
Originally Posted by WaltNYC
Rave chapter 54, page 4.
Find RAVE in the link in my signature.
11. Clean stub axle and drive shaft and fit hub
assembly to axle.
12. Fit spacing washer.
13. Fit hub adjusting nut. Tighten to 61 Nm.
14. Back off adjusting nut 90°. Tighten to 4 Nm.
This will give the required hub end float of
0,010mm
15. Fit a new lock washer.
16. Fit locknut. Tighten to 61 Nm.
17. Tab over lock washer to secure adjusting nut
and locknut.
solid gold, thank you
Old Dec 8, 2021 | 01:22 PM
WaltNYC's Avatar
You are cheating yourself if you haven't downloaded the manuals (RAVE) yet. They are, as you say, solid gold.
Old Dec 8, 2021 | 02:04 PM
DiscoNewbe's Avatar
I have the Rave manual for a 95, 96 from you, but I have a 1999 D1? You don’t happen to have a manual for that year do you? It seems like some things are different
Old Dec 9, 2021 | 03:19 PM
WaltNYC's Avatar
"This workshop manual covers vehicles from 1995
model year onwards. Amendments and additional
pages will be issued to ensure that the manual
covers latest models. Amendments and additions
will be identified by the addition of a dated footer
at the bottom of the page."
The electrical manuals are different. The Workshop manual simply has some minor revisions.
Old Dec 14, 2021 | 06:25 AM
DiscoNewbe's Avatar
thank you for that
Old Apr 9, 2026 | 03:39 AM
jannickz's Avatar
I wouldn’t “split the difference” or back it off arbitrarily—axle nut torque is critical because it sets the correct preload on the bearings, and running the wrong preload can cause premature wear or failure; if the revised spec is indeed lower (around 250 Nm / ~184 ft-lb depending on the application), then it’s best to follow the correct updated spec rather than what it was previously tightened to, and re-torque properly rather than just loosening it slightly, because bearings don’t “remember” the old load in a way that makes this risky, but incorrect preload absolutely can cause issues over time, so stick with the manufacturer’s latest spec for proper bearings life and performance.
pottzie
Jun 8, 2013 08:49 AM
Eaglerover22
Jul 5, 2012 09:01 AM
Mountain Goat
Aug 6, 2011 04:21 PM
Rover Chris
Aug 23, 2010 08:03 PM
kenk
Dec 19, 2009 04:13 PM
