Quoted $1100 for all 16 rocker arms replaced.. cant I do just the bad 1 myself?
Old May 15, 2012 | 03:34 PM
nelsontod's Avatar
yup, saw that. ok.....hhmmmmmm. ready set go?...LOL
Old May 15, 2012 | 03:39 PM
nelsontod's Avatar
my main concern with the rods, is that they needed to be in some sort of height sequence for timing purposes,,,.. but your saying that they all are the same height , its just you want to keep them in order to put them back into the same order/environment they came out of?
advntrjnky's Avatar
The rocker arms don't have sides pertaining to the vehicle. It's how they are paired up on the rocker tree. the valve stem contact points are slightly offset.
advntrjnky
Old May 15, 2012 | 03:55 PM
yes, put rods back in exactly like they came out. If you want to put a piece of masking tape on them with a number, that is fine also, just take the tape off. And if you order rocker arms, 8 of each, if doing one (maybe the budget won't allow it) order the pair (left and right).
Old May 15, 2012 | 04:00 PM
nelsontod's Avatar
why the pair? not just 8 left and then some other day 8 right?
Old May 15, 2012 | 04:07 PM
nelsontod's Avatar
If its not to much to ask, I would still like a little brain power on developing a list of all the things I will need to do this job. I have never done much outside a valve gasket and alternator, so any one that can help me shore up the learning gap with a list would be greatly appreciated.
Old May 15, 2012 | 04:32 PM
nelsontod's Avatar
sorry to be toppsy turvvy on everyone, but I just went down and took another look at it. I think I will pay to have them both done. to much crap for me to screw up under there. Thank you for all your feed back!
Old May 15, 2012 | 05:06 PM
advntrjnky's Avatar
IMHO if you can do valve cover gaskets on a Discovery you can do this job. Here is a link at AB to a complete set of everything needed (probably not need everything pictured). IIRC the RAVE covers the assembly/ installation of the shaft pretty well. the most complicated part is making sure that the "notch" in the end of the shaft is forward.
Land Rover Rocket Shaft Assembly (Same Fit As Genuine Part # 611660) | Land Rover Engine Parts
advntrjnky
Old May 15, 2012 | 05:21 PM
jafir's Avatar
Old May 15, 2012 | 05:45 PM
nelsontod's Avatar
I just spoke with the shop. They said that they can do just the right side, (easy side) for 600. I think after I get everything set up myself I will be close to that anyway, so I am going to go ahead and have them do it at some point in the near future.
