R380 Fluid
Old May 21, 2019 | 10:23 AM
jonesy-1's Avatar
Default R380 Fluid
Hi Guys - going to do some maintenance on the 5 speed over the weekend, an cant seem to find a consistent answer on what oil to use in an r380 trans.
Whats the opinion??
Old May 21, 2019 | 02:41 PM
WaltNYC's Avatar
The service manual can be found in the google drive link in my signature. Have at it.
See this page as well.
http://rovers.red90.ca/MTF.htm
Old May 22, 2019 | 05:58 AM
Toran's Avatar
Takes about 2.5 qts of fluid. I used Redline MTL.
32mm for the drain plug
T55 for the fill plug
**Make sure you can remove the fill plug first**
Old May 22, 2019 | 08:20 AM
jonesy-1's Avatar
Thanks! Yep will have to look and see if I have a T55
Old May 22, 2019 | 08:31 AM
Toran's Avatar
Also make sure the fill plug is good-n-clean so you can seat your tool on it for removal, if not it may strip the bolt and it will be harder to remove.
I used a toothpick and some shop rags.
Old May 23, 2019 | 10:14 AM
archaeology_student's Avatar
Talking
x 2 on Redline MTL which has the proper additives and composition that does not eat our internals with the yellow metals in our transmissions
Spike555
Dec 22, 2018 02:36 AM
Prattvilledisco
Sep 29, 2016 12:35 AM
jdelp
Sep 20, 2007 11:23 AM
dalfier
Jun 21, 2007 01:45 AM
