radio installation
Old Apr 1, 2014 | 07:58 PM
  #61
MM3846's Avatar
does anyone have a picture of this amp? i found traces of a cd changer under my driver's seat (wiring, no changer) and there is a box under my passenger seat... not 100% sure it is the amp. i hardwired the front two speakers but dont want to run new wires for the rear two at the moment.. i have a 95.
Old Apr 1, 2014 | 07:59 PM
  #62
MM3846's Avatar
Originally Posted by TOM R
OK how do you get the factory radio out? Guessing something to do with the 2 holes
i used a coat hangar... push the hangar into both holes at the same time and pull out the radio by grabbing the tape deck and pull straight out. its kind of hard to do without three hands but comes right out.
Old Apr 1, 2014 | 08:07 PM
  #63
MarkSF's Avatar
Originally Posted by hankwhite
No sound. Only power. Not even a hum. That's the mystery. I've got three multi-plugs: Grey, Yellow and pink. The Grey and Yellow have 8 pins and are both connected via this harness. I'm guessing they are the ISO A and B's? But then wouldn't I be getting sound?
I will find the amp and see what going on there.
Yes that's right, those are the ISO A & Bs.
Here is a useful article :
Connectors for car audio - Wikipedia, the free encyclopedia
I can think of two reasons for the lack of sound : firstly, the amplifier is not powering up. This could be because it's not getting the signal from the stereo to do so. I think it gets this through the "antenna motor out" signal, A pin 5.
Secondly, the stereo is permanently in mute mode. I say this, because I had the same problem. I had to cut the wire to connector A, pin 2, "phone mute". before I got any sound.
Old Apr 1, 2014 | 08:12 PM
  #64
TOM R's Avatar
Does the trim plate need removal? Or just pop out the radio?
Old Apr 1, 2014 | 08:17 PM
  #65
MM3846's Avatar
nope. push the releases in those holes and pull the radio straight out. they make keys to do it but i've always used a coat hanger.
Old Apr 1, 2014 | 08:37 PM
  #66
TOM R's Avatar
Thanks
Old Apr 1, 2014 | 11:04 PM
  #67
abran's Avatar
Really? There are Allen head bolts in those holes. You can just push on them and they release?
I've never tried that. Anybody else have this experience?
Old Apr 2, 2014 | 02:09 AM
  #68
CUpgt's Avatar
They aren't Allen heads, it's some other similar pattern. Same as iPhone screws. When they are threaded in the push out tabs that hold the radio in. They must be threaded out to remove the radio. I used an Allen wrench at a slight angle to release them. A small Phillips head screw driver also kinda works.
Old Apr 2, 2014 | 06:59 AM
  #69
TOM R's Avatar
Must be the star bits like the back of a wii console, cheap in bulk on eBay for screwdrivers
Ian your pm box is full and bouncing messages
Old Apr 2, 2014 | 08:35 AM
  #70
MM3846's Avatar
really? mine must have not been fastened correctly then. or i just pushed hard enough and broke them.
