radio installation
Old Apr 2, 2014 | 09:09 AM
  #71
CUpgt's Avatar
I doubt you broke it, it's pretty robust for radio mounts. Screws weeeproba bly a little loose. Tom, PMs are cleared up.
Old Apr 23, 2014 | 02:34 PM
  #72
95RRCLWB's Avatar
Just got my new deck installed today on my 98 D1. Bypassed the factory front amplifier as per the instructions on this thread. Worked great. Thanks.
However, the bass is a bit weak with just the factory speakers and since I already got the factory subwoofer in the back door, I want to see if it is possible to get it to work with the aftermarket head unit.
I want to use the new head unit's internal amp for the 6 speakers(4 door speaks and 2 tweeters), and use the factory subwoofer and it's own amp.
I am trying to avoid doing major wiring work and utilize what I already have on the truck.
The main issue is to get the factory subwoofer amplifier to power up.
This is what I did:
1. Locate the factory front amp white 18 pin connector(C2054).
2. Locate Light Green/Purple wire(LGP, pin 9). This is the hot on ignition key on wire.
3. Locate Purple/Yellow wire(PY, pin 14). This is the subwoofer amp power wire.
4. Connect the two wires LGP and PY.
5. On the same connector(C2054), locate Red wire(Pin13) and Black wire (Pin 12). These are the pre-amp audio signal.
6. Connect these two wires to your deck's subwoofer low level output(RCA).
Mine worked with just the red wire (pin 13) connected but it got ignition noise. Once I hooked up the black wire (Pin 12), no more humming.
Attached Thumbnails radio installation-20140422_160122.jpg   radio installation-20140422_160023.jpg
Old Apr 23, 2014 | 05:49 PM
  #73
MM3846's Avatar
nice, you pretty much confirmed what i found out. i planned on removing the factory amp and speakers, and replacing with this stuff in the factory housing...
amp
BOSS R1002 RIOT 200 Watt 2 Ch Amplifier | 265-3980
speakers
Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker | 264-919
my factory subs fell apart
Old Apr 24, 2014 | 11:40 AM
  #74
WaltNYC's Avatar
this may help...
https://landroverforums.com/forum/di...-wiring-43689/
Old May 24, 2016 | 11:50 PM
  #75
ImNotTheStig's Avatar
Big thank you to Rover Chris for the step by step guide like 4 years ago haha, just went through the thread and it helped me out a ton to bypass the amp and finish my install. No more driving in silence!
Old Jun 25, 2025 | 10:45 AM
  #76
gcawley's Avatar
2025 Update. The NVX 4 channel Line Output Converter.
I have a 1994 Disco1 with amp and have been trying everything on the market to eliminate the alternator whine. When I hooked the NVX up with the Metra adapter there was no whine. I just had to connect the harness and NVX. No running wires, no bypassing the amp. I tried all the ground loop, ferrite magnets, line in suppresser, the recommended Scosche, and direct ground wire to the battery. Nothing worked except the NVX.
Metra 70-9400 Radio Wiring Harness for Land Rover/Discovery
Amazon Amazon
Amazon Amazon
NVX XMICROLOC4 | 600W 4-Channel Speaker Cable to RCA Adjustable Line Output Converter with Remote Turn On Trigger
Amazon Amazon
Amazon Amazon
bballjames
Jun 22, 2012 04:50 PM
thomas22
Jun 15, 2009 10:38 AM
phidelt583
May 1, 2009 11:36 PM
agentmilo
Audio/Visual Electronics
May 4, 2007 06:41 PM
