Random vibration
Old Jan 6, 2019 | 04:25 PM
aemnky606's Avatar
So far everything is looking good. I did find a little movement on the drivers wheel rechecked the bearings everything there is good so swivel rebuild is happening next sat. Also have new transmission mounts on the way. The other ones look a little flat.
Old Jan 6, 2019 | 07:53 PM
jerichards93's Avatar
I am currently having the same problem with my D2, I have replaced front driveshaft, all sway bar end links (not that they would cause the shake, but..), upper and lower ball joints, also put new EBC rotors and pads up front. Still no fix. I have had my tired balanced as well, the tire store didnt tell me they were good but I think they would have told me if they noticed a problem. Tires are only a year and a half old with around 6k miles. If you come up with a solution please share, I could have something similar going on.
Old Jan 7, 2019 | 11:37 AM
hrhoward's Avatar
How does the rear A-arm ball joint look?
Old Jan 7, 2019 | 04:55 PM
aemnky606's Avatar
was changed out when I did all my bushings 6 months ago.
Old Jan 7, 2019 | 05:15 PM
hrhoward's Avatar
Might you have crossed a practitioner in the voodoo arts?
Old Jan 29, 2019 | 02:43 AM
user 739349's Avatar
Banned
Hahaha, this comment made me laugh so hard
Old Feb 9, 2019 | 05:53 PM
aemnky606's Avatar
So I was adding a new power panel at work yesterday and I needed more light so I pulled my truck in to the warehouse to use my light bar, about 20 mins later the light came on in my head and realized I had to change out the light bar due to failure. So I removed it and have been on several trips and no vibration. I think I found my problem. Time will tell.
Old Feb 13, 2019 | 01:18 PM
hrhoward's Avatar
Still, you might want to mix some jimson weed with sulfur and honey in a glass and rub some against a black cat before slowly sipping the remainder, whilst sitting in your truck.
(Note: rub the cat while outside of your truck, no cat rubbin' inside the truck. Leave cat outside!)
Old Feb 13, 2019 | 04:22 PM
aemnky606's Avatar
HAHAHA. That's a good idea.
Old Feb 18, 2019 | 04:12 PM
jbunner's Avatar
I was going to say check the wheel bearings. I took mine and all they did was rotate the tires. The vibration was worse so I went straight to another shop and the wheel bearing was so loose the tire was about to fall off.
san988
Nov 27, 2025 02:36 PM
PAPAGALLO
Jan 23, 2017 06:23 AM
oysterhead
Oct 28, 2009 09:56 AM
squid
Freelander
Mar 18, 2009 06:44 AM
LiftedRover96
Feb 7, 2006 10:41 PM
