Re-soldered windows ECU, but problem is still there.
Hello guys.
Two days ago I took out my windows ECU and found 4 or 5 problems with the soldering. Re soldered all of them, installed the ECU again, and the rear windows still do not work.
I really would like to repair the problem without buying new ECU and without bypassing it. But, if the ECU is bad, then I will bypass it.
Is there any other common problem I can check?
Thanks!
Thanks!
When I did mine a week ago the first time I went through it didn't fix anything so I pulled it out and went over it again and re-soldered joints that didn't appear to have any problems, then it worked.
________
Suzuki GN Series specifications
________
on
Like Larry the Cable Guy says, " Now that is funny, I don't give a damn who you are, That's Funny!"
Sometimes you just don't see those little solder defects. I have seen plenty with other 30 years experience on aircraft and missile systems. And those minor defects can take you down hard.
bcolins
02-01-2015 07:05 AM
StormTroopa
11-28-2009 06:45 AM
