Re-soldered windows ECU, but problem is still there.
Old Sep 6, 2010 | 03:04 PM
johnkbl's Avatar
Default Re-soldered windows ECU, but problem is still there.
Hello guys.
Two days ago I took out my windows ECU and found 4 or 5 problems with the soldering. Re soldered all of them, installed the ECU again, and the rear windows still do not work.
I really would like to repair the problem without buying new ECU and without bypassing it. But, if the ECU is bad, then I will bypass it.
Is there any other common problem I can check?
Thanks!
Old Sep 6, 2010 | 03:09 PM
Henrici's Avatar
When I did mine a week ago the first time I went through it didn't fix anything so I pulled it out and went over it again and re-soldered joints that didn't appear to have any problems, then it worked.
________
Suzuki GN Series specifications
Old Sep 6, 2010 | 03:22 PM
johnkbl's Avatar
Well.... start over.
Ok! Will do it. Thanks!!!
Old Sep 6, 2010 | 03:36 PM
Henrici's Avatar
I was pretty bummed when mine didn't work the first time too. And I really didn't expect anything the second time. Figured it was above my skill level....
Old Sep 6, 2010 | 05:50 PM
Danny Lee 97 Disco's Avatar
And I always thought any damn fool could solder..............
Old Sep 6, 2010 | 07:11 PM
Henrici's Avatar
yeah it just takes us two tries
________
Subaru Alcyone SVX
Old Sep 8, 2010 | 10:57 AM
johnkbl's Avatar
Wink
Not funny!
Old Sep 8, 2010 | 11:40 AM
ngarover's Avatar
God, when I think of the hours I use to spend looking over solder points on circuit boards with a jewelers magnifier...
Old Sep 8, 2010 | 06:57 PM
Originally Posted by johnkbl
Not funny!
Like Larry the Cable Guy says, " Now that is funny, I don't give a damn who you are, That's Funny!"
Sometimes you just don't see those little solder defects. I have seen plenty with other 30 years experience on aircraft and missile systems. And those minor defects can take you down hard.
bcolins
Feb 1, 2015 07:05 AM
FLA Rover
Aug 16, 2013 08:26 PM
Spencerfitch
May 28, 2010 06:34 PM
StormTroopa
Nov 28, 2009 06:45 AM
