Rear a/c delete
Has anyone figured a way to block off the rear a/c line? I have a leak in the rear line and just want to block it off all togethor. I guess off the high presseure line were it runs back i need to block it off?
Any advice ?
Thanks jon
Any advice ?
Thanks jon
Yes it would take some special caps. Or if you have a shop that can custom make you an A/C line that could "loop" it back instead of using caps. Not a bad idea. This is what I will do if my DI A/C rear fails. How much for the hose?!
the hose is very expensive and considering I allready bought a high pressure line, just going to block the fittings. I found both the hoses were to block the rear system.. its right at the passenger frail rail next to bellhousing. So I went and took some back fittings off , found the exact same fittings I need to block.Sending them to this place StreetRodGuys - Rear Air Conditioning Block Kits. I'll take pics and show how its done for anybody interested.
thanks jon
thanks jon
im super interested. you can pull out that crappy plastic window that blocks the alpine although there may be some fitment issues. you could also put a cargo box in its place.
sava said something about the condensor being not the right size for a single AC although i probably got that wrong.
I just removed the rear AC and all the lines up to the main front lines. I ended up cutting the front lines where they tee to the rear. I'll either braze them closed or find lines from one without rear AC.
hillstrubl, where do you live? I might have a few old lines left.
