Rear a/c delete
Old Jul 8, 2012 | 03:19 PM
Maddwrenches's Avatar
5th Gear
Default Rear a/c delete
Has anyone figured a way to block off the rear a/c line? I have a leak in the rear line and just want to block it off all togethor. I guess off the high presseure line were it runs back i need to block it off?
Any advice ?
Thanks jon
Old Jul 8, 2012 | 03:27 PM
You will need to remove both the intake as well as the return lines and I have to think it will take some special a/c caps to close of the rear from the front system.
Old Jul 8, 2012 | 07:42 PM
oilspotLR's Avatar
Yes it would take some special caps. Or if you have a shop that can custom make you an A/C line that could "loop" it back instead of using caps. Not a bad idea. This is what I will do if my DI A/C rear fails. How much for the hose?!
Old Jul 9, 2012 | 06:33 PM
5th Gear
the hose is very expensive and considering I allready bought a high pressure line, just going to block the fittings. I found both the hoses were to block the rear system.. its right at the passenger frail rail next to bellhousing. So I went and took some back fittings off , found the exact same fittings I need to block.Sending them to this place StreetRodGuys - Rear Air Conditioning Block Kits. I'll take pics and show how its done for anybody interested.
thanks jon
Old Jul 10, 2012 | 10:56 AM
slanginsanjuan's Avatar
im super interested. you can pull out that crappy plastic window that blocks the alpine although there may be some fitment issues. you could also put a cargo box in its place.
sava said something about the condensor being not the right size for a single AC although i probably got that wrong.
Old Jul 10, 2012 | 03:07 PM
hillstrubl's Avatar
I'm actually trying to fix the rear A/C of my '96 Disco 1. Anybody have an exploded view of the lines? the P.O. removed them due to having a leak. I wanted to get new ones and get this working again.
Old Jul 10, 2012 | 04:49 PM
EricTyrrell's Avatar
I just removed the rear AC and all the lines up to the main front lines. I ended up cutting the front lines where they tee to the rear. I'll either braze them closed or find lines from one without rear AC.
hillstrubl, where do you live? I might have a few old lines left.
Old Jul 10, 2012 | 05:51 PM
hillstrubl's Avatar
Hey Eric, im in Philly
Old Jul 10, 2012 | 05:58 PM
That's quite a ways from me. I'd just go to a pick-n-pull and get what you need.
Old Jul 10, 2012 | 06:04 PM
Don't forget that refrigerant charge will be less on the front only system (900 grams, vs 1150 grams for front and rear air system).
