Rear left door wont open
The door was opening and closing fine for as long as i have had the disco, but now out of the blue after some mudding it wont open. It seems to lock and unlock ok, but it wont open. From what i have read it could be the lock actuator or something like that. Or i could try lubricating it, but how do i open the door to be able to lube it?
I assume you have tried from the inside too.
There is a rod that goes from the inside/outside handles to the latch, that rid can come unhooked from the latch inside the door.
Usually there is some warning before hand, like the handle needs to be pulled farther than normal to open the door.
You are going to have to remove the inner door panel, thats going to be hard but doable.
Remove the inner door handle (the thing you use to close the door) and then the inside door release.
You can then pull the door panel away from the door, the door panel fits inside the cabin so the door jamb will not stop you, but it will be difficult.
Good luck.
If you really dont want to mess with it take it to a body shop.
Good luck.
The door panels are made of structural foam, use plastic upholstery tools or a putty knife and be gentle, the plastic fasteners will rip out easily. You may want to look over these pages from the RAVE shop manual that cover the process.
The door panels pop off pretty easily once you know where all the fasteners are. In my experience the most annoying part is getting the handle screws back in when you're done!
I can tell you exactly what happened, it was cold, possibly frozen, sun warmed it up and now it works, but soon it will break.
I had this exact same problem on my drivers door, hand to pull the handle farther than normal to open the door, it's winter, "I'll take care of it in the spring"
Below zero temps, cant open door, have to climb over center console to get in and out.
First "warm" day I had to remove the door panel and adjust the latch.
If you remove the door panel you can adjust the inside door release handle, there are two slide screws, loosen them, slide the handle forward, tighten screws, test, the handle should be firm and open the door within the first few cm's of movement.
bcolins
11-08-2011 06:15 PM
marlymarl
07-28-2005 12:23 AM
