Rear wiper and rear fog buttons
I had the same issue once you remove the switches from the dash make sure to remove the bulbs before disassembling the switches using 2 flat blade pocket jewelers screwdrivers press into rear of switch to unlock the 4 small tabs, then slide apart, use an eraser some electronic cleaner to clean the contacts as they will have corrosion on them then apply a little die-electric grease and assemble. Plug into car and test remember to start the vehicle I believe the rear defroster will not work unless the ignition is on. Good luck.
bcolins
02-02-2014 09:40 PM
bcolins
06-22-2013 08:55 PM
Rudnicken
13
12-06-2010 01:49 AM
