Rekey and rear door troubles?
Old Jan 19, 2021 | 05:33 PM
DurhamD1's Avatar
7th Gear
Default Rekey and rear door troubles?
My D1 had the ignition replaced, so it came with 2 sets of keys...that each had 2 keys. One key to open the doors, one key to start the truck. Is it very difficult, or even possible without taking it to a dealer, to rekey all the doors and the fuel tank? I'd like to be able to just have the one key, and not have to fumble around for which is which.
Also, the rear door locks by the remote fob (generally), but will not open by it. You have to open the door with the original key. Anyone have thoughts on that? I've never messed with car doors before.
Thanks!
Old Jan 21, 2021 | 11:14 AM
jimvw57's Avatar
Might be easier to re-key the ignition lock.
Old Jan 21, 2021 | 12:00 PM
jvarnadoe's Avatar
I agree with Jim that it'd be easier to just rekey the ignition lock using your door lock keys. My key broke off inside the ignition lock, so I had to remove the lock mechanism to retrieve the other half of the key. I had copies made of the original years ago, but they never worked correctly. I put the copies in the lock mechanism and filed the tumblers flat as referenced in the thread below. Good luck!
https://landroverforums.com/forum/di...ock-fix-35422/
Old Jan 21, 2021 | 02:59 PM
DurhamD1's Avatar
7th Gear
Thanks! Will this not make it significantly less secure? Multiple keys could start it? I guess I have the other keys that still could though...
Old Jan 22, 2021 | 08:22 PM
jvarnadoe's Avatar
Once you file the tumblers to match the door lock keys, the other keyset that used to start the truck won't work any longer.
SmithZ80
Dec 6, 2020 03:26 PM
Drubie22
Sep 24, 2014 09:29 PM
grcurry
Mar 17, 2014 12:51 AM
Disco Dancer
Oct 29, 2013 09:48 PM
Disco2Guy
Sep 21, 2007 09:20 PM
