remote keyless entry
Old May 11, 2012 | 09:03 AM
discoguy96's Avatar
Default remote keyless entry
My father-in-law didnt have the remote fob for the 96 disco that i just got. I've found a couple used ones on ebay but will I be able to program it myself or do I have to take it to the factory. I found some info on a website about turning the ignition on,off then locking and unlocking the door then ignition on and off again to enter programming mode but I wanted to make sure that was correct.
Thanks all.
Old May 11, 2012 | 01:46 PM
discoguy96's Avatar
Actually, i found the instructions in the discovery workshop manual but part of the instructions is to depress the bonnet switch.
What the heck is a "bonnet switch"?
Old May 11, 2012 | 02:30 PM
Chris-bob's Avatar
The bonnet is the hood. It is a switch that tells the ecu that the bonnet(hood) is open/closed.
Old May 11, 2012 | 03:36 PM
discoguy96's Avatar
Thank you. I guess I gotta figure out where the bonnet switch is now unless someone happens to know off the top of their head.
Old May 11, 2012 | 04:40 PM
tweakrover's Avatar
It's a little plunger on the passenger side.
Old May 11, 2012 | 08:26 PM
Best thing you can do is unplug it. If battery goes dead while alarm armed, causes all kinds of problems when you try to jump it off. Getting into a locked hood is very difficult, I'll take the risk that some one wants my 2 year old battery vs immobilzation at the wrong time.
Old Aug 12, 2012 | 08:19 PM
coldstart's Avatar
Default remote programming
how did you make out I have the same issue can you tellme what you did to make the used remote work thanks
Old Aug 14, 2012 | 06:59 PM
discoguy96's Avatar
I never could get it to enter program mode, the bonnet switch may be bad i guess. I quit trying.
Good luck.
Old Aug 15, 2012 | 09:15 AM
coldstart's Avatar
could you tell me where you found the instructions in the workshop manual ,I have gone through and did not see anything thanks
Old Aug 15, 2012 | 03:33 PM
Danny Lee 97 Disco's Avatar
Best way to treat one of those key fobs is to place it i a vice and tighten securely, if a vice is unavaiable (like in Spike's case with no workbench) then place it on a flat surface and strike firmly with a large hammer.
Repeat if needed!
