remote keyless entry
Old Aug 16, 2012 | 07:29 AM
georgep's Avatar
Originally Posted by Danny Lee 97 Disco
Best way to treat one of those key fobs is to place it i a vice and tighten securely, if a vice is unavaiable (like in Spike's case with no workbench) then place it on a flat surface and strike firmly with a large hammer.
Repeat if needed!
I translate that as to they DO NOT WORK worth a dam! Mine in the 2001 works well but do not have one for the 1998 was going to the dealer for one. Not worth it??
Got the answer
This replacement remote must be programmed electronically to function with the vehicle.
This programming can be done by your local Land Rover dealer or an independent shop with key coding diagnostic equipment for Land Rovers
Old Aug 16, 2012 | 03:56 PM
Danny Lee 97 Disco's Avatar
Mine was touchy with the unlock button even after a battery change, so I did away with it. Using the key in the door will still lock it and set the basic perimeteric alarm as the blinkers do flash 3 times to show the alarm is on.
As many horror stories as I have seen regarding alarm immobilization issues, I prefer to avoid that as much a possible. To me a spare key is more important, especially if you only have one. I have seen them break off in the ignition and if you only have one, that is a major situation.
Some people do prefer to have a key fob for convience. I don't care for them on mine.
Frank4
Mar 21, 2014 05:21 AM
landroverlover
Sep 14, 2008 07:24 PM
rth790
Dec 7, 2007 06:51 AM
whigham42
Sep 29, 2007 08:09 PM
cowgirl1989
Feb 18, 2007 11:54 AM
