Repairing the VSS
Old Jan 31, 2013 | 12:31 PM
gprtech's Avatar
I'm glad it worked for you.
I'm looking at putting in a ball bearing instead of the nylon washer. That should make it a permanent fix.
Old Aug 1, 2013 | 09:18 PM
TOM R's Avatar
Did you ever make the ball bearing work?
Old Aug 2, 2013 | 05:04 AM
gprtech's Avatar
Yes, but I've been so busy fixing all of the rest of the stuff on the truck I haven't had a chance to document it.
Latest was replacing the downstream oxygen sensors. The bung on one was corroded away, so I needed to cut it off and weld in a new one. The reward? It's telling me the catalytic converter has low efficiency.
New catalytic converter on order.
Old Aug 2, 2013 | 08:33 AM
Magna Defender's Avatar
Thanks, Tom, for checking with George (gprtech) for an update on his ball bearing fix. It looks like I might be following in his footsteps with repairs on my 1997 Dscvry. I'll be reading alot of his threads. I appreciate it .
I hope my catalytic converter isn't next . I'm still researching the cause of my P0430 symptom, but have been busy.
Old Aug 2, 2013 | 03:44 PM
gprtech's Avatar
I'll try to update the instructions this weekend. It's supposed to rain anyway. :-(
Old Aug 2, 2013 | 05:00 PM
TOM R's Avatar
This is on the to do list even though it is not bad yet
Old Aug 7, 2013 | 03:43 PM
archaeology_student's Avatar
Just wanted to say thank you to gprtech!
Followed this rebuild and so far so good! Only thing is no one had the washers needed, not even Home Depot locally (tried both nearby stores) in Vancouver, BC, Canada
I did notice one odd thing though, that the magnet and the spinning unit/sensor has tiny clips that are glued inside the magnet. I guess that once it is pulled apart it does not keep it in place as well... my solution was a touch of gasket sealand applied to the shaft that fits into the magnet... seemed to keep it in place.
Old Aug 7, 2013 | 04:06 PM
TOM R's Avatar
Home depot does carry the ones used by op but my local was out of just that size, got a set at Lowes not sure if they work yet
Old Aug 7, 2013 | 10:35 PM
Sometimes what is carried in the US stores is not carried in the Canadian stores, and vice versa
Old Aug 13, 2013 | 07:06 AM
Question
Hmmm... looks like my Speedo is on the fritz again... gonna have to rebuild it again... would love to know the ball bearing dimension so I can find one
