Repairing the VSS
Old Feb 10, 2021 | 07:17 PM
  #61
nzajg's Avatar
Hello gprtech. I'm still having a problem with my D1 with an intermittent repetitive cutting out. I installed a used VSS which didn't solve the problem, but for diligence sake I would like to refurbish the unit. Unfortunately your link is not connecting, could you please repost? Appreciated, many thanks. regards Tony G. NZ
Old Feb 10, 2021 | 11:26 PM
  #62
disco96sd's Avatar
buy a new one and dont get a knock off brand - get a LR part
lot of failures with this part
Old Feb 11, 2021 | 07:02 AM
  #63
WaltNYC's Avatar
here it is
File Type: pdf
Old Aug 19, 2023 | 10:15 AM
  #64
shoard's Avatar
Default Broken Link to PDF
Originally Posted by gprtech
I've seen quite a bit of chat about unidentified problems and the possibility of the VSS being the cause.
Because the previous owner of my truck sold it because of these types of complaints, I was very interested in the VSS. I bought one on Ebay to rip apart, and when I found how easy it was to work on, and what was wrong with it, I took the one out of my truck, did the same and documented it.
You can get the write up here:
http://www.key-men.com/downloads/Lan...rebulid_v1.pdf
My guess is that at this point, most of these trucks need this rebuild whether or not you've seen the symptoms.
I'll be revising this if I can find a more suitable part, and I'll update the thread if that happens.
Hello, is there anyway you could repost the write up for the vss rebuild? It would be greatly appreciated. The link seems to be broken. Best!
Old Aug 20, 2023 | 12:35 AM
  #65
jvarnadoe's Avatar
Walt's link from Feb 2021 still works.
File Type: pdf
Old Aug 21, 2023 | 02:07 PM
  #66
WaltNYC's Avatar
Get one of these. Much easier to access.
Amazon Amazon
chelvey@helveyconsulting.com
Mar 11, 2016 01:44 PM
TRIARII
Dec 31, 2013 09:33 AM
abran
Dec 3, 2013 09:21 AM
vorticistssuite
Nov 23, 2013 03:20 PM
elboy0712
Feb 19, 2010 07:09 PM
