replace "city" lights with LED?
Yep, not sure they will like the temps that come with the main lamp. Also, you might want a small LED bulb style that projects light in several directions, so the reflector will work with it, as oposed to an LED style that just has light straight off the main axis. See 18 High Power SMD LED 3156/3157 Tower Bulb Specifications
Some owners have used the regular small bulbs that have been colored (green, etc.). There may be local laws about that however.
The city lights are the small "194" style bulbs mounted in the headlight assemblies below the headlight bulb. They are designed to come on when the headlight switch is turned to position 1 for the running lights. I believe they are designed to be used when in dense urban areas, where homes are tightly packed, so your headlights don't shine into your next door neighbor's living room window.
