replace "city" lights with LED?
Old Dec 26, 2011 | 09:20 PM
s10lowrider1994's Avatar
Default replace "city" lights with LED?
Is there an LED bulb available that will replace the "city" lights in our headlamps? Mine make my headlights look so yellow and I want to upgrade headlight bulbs soon so I was hoping there was an upgrade available for the city lights as well?
Old Dec 26, 2011 | 09:24 PM
DonRW2007's Avatar
Default Tree are some available
You will find LEDs on the typical sites that offer them. However, the intensity of the regular lamps in the headlights will quickly destroy them...
Old Dec 26, 2011 | 09:33 PM
Yep, not sure they will like the temps that come with the main lamp. Also, you might want a small LED bulb style that projects light in several directions, so the reflector will work with it, as oposed to an LED style that just has light straight off the main axis. See 18 High Power SMD LED 3156/3157 Tower Bulb Specifications
Some owners have used the regular small bulbs that have been colored (green, etc.). There may be local laws about that however.
Old Dec 26, 2011 | 09:37 PM
I've found some standard bulbs witha different hue but they are pricey so I thought the LED may be a better option. Guess I'll grab the matching city lights when I order my new headlight bulbs and not bother with LEDs.
Old Dec 27, 2011 | 06:57 PM
Why even bother with the city lights?
Mine have been burnt out for years and I just dont care.
Old Dec 27, 2011 | 10:06 PM
Around here it won't pass inspection with them installed but not working so I figured since I have to keep them they may as well look good
Old Dec 28, 2011 | 11:00 AM
Chris-bob's Avatar
How will they know it is supposed to have them?
Old Dec 28, 2011 | 06:16 PM
My thoughts exactly.
They have you turn the lights on, they wont know there are supposed to be bulbs in there.
Old Dec 29, 2011 | 08:15 AM
slanginsanjuan's Avatar
what is a city light?
Old Dec 29, 2011 | 09:40 AM
lordmorpheus's Avatar
The city lights are the small "194" style bulbs mounted in the headlight assemblies below the headlight bulb. They are designed to come on when the headlight switch is turned to position 1 for the running lights. I believe they are designed to be used when in dense urban areas, where homes are tightly packed, so your headlights don't shine into your next door neighbor's living room window.
