Replaced 2 upstream O2 sensors- new code & question
Old Feb 15, 2011 | 05:04 PM
Garrett's Avatar
Default Replaced 2 upstream O2 sensors- new code & question
So for a few days all was well.
Today the CEL popped on so I read it and it spit out P0420.
Catalyst System Efficiency Below Threshold (Bank 1)
I think the cat's dead, what say you? Also, when I was under there doing a starter and the sensors, I noticed the converts on both sides don't match. Is this normal? Both were badged Rover on them Factory replacement on one side perhaps?
Anyone had any luck with Magnaflow cats? Are they enough to satisfy the car's OBD system?
Old Feb 15, 2011 | 05:33 PM
demonlarry's Avatar
do a lot of research on this one. replaced the front and rear o2 sensors on my wife's car, then I got that code.
wasn't the cat. bad rear o2 sensor.
Old Feb 15, 2011 | 05:59 PM
jafir's Avatar
This is normal. There just isn't as much room on the side with the flatter, lower profile cat.
Old Feb 15, 2011 | 06:30 PM
To rule out the cat swap the "bad" O2 with the new one and see if the code follows.
Yes the OEM cats are not the same on both sides, space issues.
Old Feb 15, 2011 | 06:37 PM
Garrett's Avatar
Would an exhaust leak pre cat on aformentioned side do that? I believe the leak is on that side.
Old Feb 15, 2011 | 06:45 PM
Yes a big leak pre-cat can set off a code.
The ECU knows how much exhaust their should be, if its wrong...code.
aftermath431
Nov 2, 2014 07:59 PM
Nailnheadbanger
Jun 17, 2014 04:04 PM
mblmaine@gmail.com
May 12, 2012 02:38 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
