Replacing blower switch
Old Jun 15, 2025 | 01:27 PM
disco96sd's Avatar
Default Replacing blower switch
Periodically my blower switch goes off on setting 4 - assume its worn - you can wiggle it a bit and it goes right back on - settings 1,2,3 never have a problem - might think about replacing it - is it pretty straight forward or does half the dash have to come out ?
Old Jun 15, 2025 | 03:29 PM
dcphotos's Avatar
Half the dash has to come out. I’m fixing to the same repair… AGAIN. I cleaned the bejesus outta the switch and it worked for all of about three weeks. Bought another to swap out.
Old Jun 16, 2025 | 07:21 AM
whiskeynipple0088's Avatar
I disassembled mine, soaked it in white vinegar, cleaned with rubbing alcohol and applied dielectric grease to the contacts.
Where did you source the one you bought?
Old Jun 16, 2025 | 11:35 PM
jimvw57's Avatar
Of course they don't make them any more, if you find a D1 with rear air, the switch for the rear air is the same and they don't get used much. The fan draws about 40-50 amps on high so it is tough on the switch. Most newer style switches can't handle it, and you will need some beefy wire so it doesn't heat up. never hurts to have a spare one on hand as they are hard to find, and cleaning them can get complicated if the fly apart or melt. Lots of springs and contacts in there.
https://www.google.com/search?q=Land...uvKcjXqOA,st:0
Old Jun 17, 2025 | 10:03 AM
dcphotos's Avatar
That’s what I did. Bought a rear a/c switch off eBay. I tried rehabbing the old switch first. Didn’t last. Won’t know why till I swap it. That’s on my To-Do list for this week.
Old Jun 17, 2025 | 10:13 AM
jvarnadoe's Avatar
Here's a link to the step by step removal from AB.
https://www.roverparts.com/instructi...CwhMoy7_Uhalt-
It's a real PITA. I replaced my switch a while back with a used rear a/c control switch, but that one is also getting wonky.
I have a complete control panel I pulled from a junker, but the center panel is so brittle that a lot of it has broken away and is cracked. I need to source a replacement panel at some point and get that "new" panel in there.
Old Jun 17, 2025 | 06:07 PM
disco96sd's Avatar
LR making something simple ridiculous - why would they do that ? LOL
I hear LR didn't higher the brightest engineers - well maybe they did - keep the production cost down and charge the customers an arm and a leg in dealer service when you have to take half the car apart to change a light bulb
calebbo
Mar 31, 2017 12:47 AM
dsmeddy
Sep 3, 2016 11:09 AM
sickvehicle
Jul 12, 2010 07:39 PM
wesk
Nov 25, 2008 08:41 AM
