Replacing Camshaft
#102
#103
#104
Here she is! Tickless!!
1995 Discovery post cam - YouTube
Even though I am a Tech, I did not use air tools. All work done with hand tools except my airlift for coolant which is nice but not necessary. I still need to set timing. She stumbles a bit even though I cleaned out the evap ports. She did this before the cam and tappet failed. I do have a code 48 but I am not worried about that.
I really hope this thread helps someone out!
#106
Yes but the timing is clearly off. I also need to do the kick down cable. I have all the parts for the kick down, including a heat guard sheath since the middle of the old cable is cooked from the exhaust. Just need motivation.
I should clarify why the code 48 is not related. I had it a couple times before the tappet/cam issue. I strongly suspect my IACV is going out. It is a sporadic issue.
#107
Its amazing how many people i've seen get hamstrung over g12 coolant if they were running low and not just top off with distilled water.. common sense isnt so common.. lol..
#108
What did you set your timing at?
I need to inspect my IACV as well. I have some random idle
#109
#110
You dont have a timing light?!!??
I have been thinking about switching to g12 for some time now.. Maybe next time I do a flush. My GF put green in the Passat once and now it needs a new heater core and has been flushed 100x trust me I wasnt happy, she learned only water from now on unless it's below freezing then it's AAA time
