Replacing Camshaft
Old Apr 16, 2012 | 11:24 PM
  #101
Danny Lee 97 Disco's Avatar
What is that pink liquid?
Old Apr 16, 2012 | 11:32 PM
  #102
ColoDisco's Avatar
Coolant. It is called G12. Common in all newer VW and Audi's. It has a coagulating property which helps slow leaks and identify where they are coming from. Since Audi uses it in their aluminum engines I decided to use it in mine.
Old Apr 17, 2012 | 01:05 AM
  #103
ValveCoverGasket's Avatar
disastrous if mixed with green coolant haha
that stuff can be a pain to find for a reasonable price if youre in a pinch...
Old Apr 17, 2012 | 04:42 PM
  #104
ColoDisco's Avatar
Here she is! Tickless!!
1995 Discovery post cam - YouTube
Even though I am a Tech, I did not use air tools. All work done with hand tools except my airlift for coolant which is nice but not necessary. I still need to set timing. She stumbles a bit even though I cleaned out the evap ports. She did this before the cam and tappet failed. I do have a code 48 but I am not worried about that.
I really hope this thread helps someone out!
Old Apr 17, 2012 | 05:21 PM
  #105
Jake1996D1's Avatar
Damn man sounds good! Does she run any better now since she can breathe?
Old Apr 17, 2012 | 05:25 PM
  #106
ColoDisco's Avatar
Yes but the timing is clearly off. I also need to do the kick down cable. I have all the parts for the kick down, including a heat guard sheath since the middle of the old cable is cooked from the exhaust. Just need motivation.
I should clarify why the code 48 is not related. I had it a couple times before the tappet/cam issue. I strongly suspect my IACV is going out. It is a sporadic issue.
Old Apr 17, 2012 | 05:30 PM
  #107
psykokid's Avatar
Its amazing how many people i've seen get hamstrung over g12 coolant if they were running low and not just top off with distilled water.. common sense isnt so common.. lol..
Old Apr 17, 2012 | 06:19 PM
  #108
Jake1996D1's Avatar
What did you set your timing at?
I need to inspect my IACV as well. I have some random idle
Old Apr 17, 2012 | 06:28 PM
  #109
ColoDisco's Avatar
I haven't Jake. Don't own a timing light. They are so cheap now I may go pick one up.
Audi sells a G12 concentrate in a quart, I have one I keep in my disco for emergencies.
It is something like 10:1. 10 parts water to 1 part concentrate.
Old Apr 17, 2012 | 06:44 PM
  #110
Jake1996D1's Avatar
You dont have a timing light?!!??
I have been thinking about switching to g12 for some time now.. Maybe next time I do a flush. My GF put green in the Passat once and now it needs a new heater core and has been flushed 100x trust me I wasnt happy, she learned only water from now on unless it's below freezing then it's AAA time
