Replacing Camshaft
Old Apr 17, 2012 | 06:51 PM
  #111
psykokid's Avatar
Originally Posted by Jake1996D1
You dont have a timing light?!!??
I have been thinking about switching to g12 for some time now.. Maybe next time I do a flush. My GF put green in the Passat once and now it needs a new heater core and has been flushed 100x trust me I wasnt happy, she learned only water from now on unless it's below freezing then it's AAA time
Uggh.. passat heater cores are fuuuun.. i've been putting off the one in mine for some time. pulling the dash vs topping up the coolant once a week.. hrmm been going the lazy route. mine's leaking where the hose meets the pipe so it just drips into the raintray..
Anyhow, back on topic.. great job on getting the lifter tick sorted. 375 for the distro kit vs 600 for the coilpack one is a bit tough to swallow..
Old Apr 17, 2012 | 06:55 PM
  #112
ColoDisco's Avatar
I know. VW and Audi abandoned that technology long ago.
Old Apr 17, 2012 | 07:13 PM
  #113
ColoDisco's Avatar
Here is a link to the stuff I used at Audi:
G12 Plus Plus Engine Coolant (1.5 Liter)
There is also pentofrost ++ and rowe ++
Old Apr 17, 2012 | 07:22 PM
  #114
Jake1996D1's Avatar
What is the actual ratio? How much did you use in the disco?
Old Apr 17, 2012 | 07:33 PM
  #115
slanginsanjuan's Avatar
that's my mechanic was worried about...timing. don't you have to take the front cover off to adjust that?
Old Apr 17, 2012 | 07:39 PM
  #116
ColoDisco's Avatar
No. You set up timing before you reinstall the cover. There is no adjusting the chain, cam gear or crank gear after that. You can adjust the distributor timing after with a timing light. Follow rave, I did and it was easy.
Old Apr 17, 2012 | 09:29 PM
  #117
ColoDisco's Avatar
Just cleaned the IACV and took its first real test drive, HOLY ****!!!
I had no idea you can take off from a green light and go faster than everyone else.
Seriously big difference!
Old Apr 18, 2012 | 12:52 AM
  #118
ValveCoverGasket's Avatar
i might have missed it earlier in the thread, but was the cam you put in hotter than the stock one?
Old Apr 18, 2012 | 07:56 AM
  #119
ColoDisco's Avatar
It is a Crower cam and tappets
Old Apr 18, 2012 | 08:35 AM
  #120
congrats Brad. I need to follow your lead and get mine done. Probably not too different for 4.0.
