Retrofit / Aftermarket Towing Mirrors?
Hello Good People,
Curious to know if anyone has switched out their door mirrors for something a bit larger?
I like the towing mirrors on the newer Rovers but not their $!
Would anyone know of a bolt on setup from another truck that would would match ours?
Thanks
Thanks
Hello Everyone,
Just an update to my first post.
It took more time looking at the bolt patterns of many truck mirrors as not to put too many additional holes in the truck. In the end I found a cheap set of Dodge Ram 1500 towing mirrors on eBay.
Measure up everything and drilled on hole on each door. These mirrors also fold in a vertical position for towing.
So far I can see more, and if its not my thing I can take them off in less than 1hr.
The glass mirror view is 11x8.5
Thanks
Thanks
The model of mirrors I used are not the electronic version.
The fit and finish is not an exact fit. The mirror slightly overlap the mounting slightly on the sides. After getting them bolted on I filled in any gaps with some black weatherproof filler.
I just wanted to see more out of the mirror with less blind spots. I was originally looking to install some D90 mirrors but after doing some research it seems as though those side mirrors break down a bit more over time due to their design.
I like stock at times and other times I enjoy customizing the truck.
