Retrofit D2/P38 Cruise Control ECU
Old Apr 7, 2013 | 10:55 AM
fishEH's Avatar
Does anyone know if the cruise and ABS are linked? I thought I remember hearing something about the cruise won't work if your ABS is disabled? Any truth to this?
Old Apr 7, 2013 | 11:58 AM
No, no truth to that at all.
Old Apr 7, 2013 | 07:42 PM
TOM R's Avatar
is it in the same location in a disco2? definitly saving this thread
Old May 26, 2013 | 08:49 AM
jdblep's Avatar
Did the swap this weekend. didnt fix my problem, but one thing to check off. My 98 Disco, used that same color wiring as the new module (not according to instructions posted here). I followed the pin-out, and the wiring was the same.
Old Jun 6, 2013 | 05:57 AM
colitatx's Avatar
Originally Posted by Paul Grant
As testimony to the reliability of the DII/P38a cruise control ECU, I have over two dozen on hand. If anyone else wants to try Eric's mod, I have plenty of 4.0 ECU's with pig tails for just $17.50 including shipping.
Is the AMR5700 and the Bosch P38 the same beast? My AMR1173 is dead and I need a pig tail for the conversion, where can I get a P38 or AMR5700? Bill Mills colitatx@yahoo.com
Old Jun 6, 2013 | 06:02 AM
colitatx's Avatar
is the amr5700 and the bosch p38 the same? my amr1173 has died, so a new more reliable unit is needed and I will need one of ypur pig tails for which ever one your pig tail fits.
thanks
bill
colitatx@yahoo.com
Old Jun 8, 2013 | 04:54 PM
Paul Grant's Avatar
Yes, the cruise control ecu is the same in Bosch P38a's. If you want one with a pigtail it's $17.50 and that includes shipping. You can PayPal me using paulgrant@mac.com or you can call me on Monday with a credit card.
Cheers,
Paul
203-770-1699
Old Jun 12, 2013 | 08:30 AM
TOM R's Avatar
Default Module location
I finaly located this module in the jy on a d2 it is located behind the pass side kick panel held in by 2 10mm nuts and you can pull it to get 6"++ of harness
Old Jun 12, 2013 | 06:59 PM
TOM R's Avatar
wired this in today, just cut off the old plug and soldered in the new plug, I now get clicks so need to recheck the pump
Old Jun 13, 2013 | 09:53 AM
jdblep's Avatar
was having the same problem after soldering in the new cruise ECU (clicks but no cruise), replaced the pump and now i have working cruise!
