Rocker identification LH vs RH .......
Ok, need to order two rockers and gotta know which to order, I know there are 2 diff ones per cyl but cant find anywhere that clearly identifies which is which.
The ones I need, standing on the drivers side, staring at the rockers, they would be on the right of the bolts..
this would be with the pushrods on the side of the rocker facing away from you.
If you have a clear way of identifying them, that would be appreciated...
Thanks!
Thanks!
yeah I screwed this up and ended up with a right I don't need
Super easy each cylinder has a left and right look at cylinder left of bolt is left rocker right of bolt is right rocker difference is offset of rocker tip where it contacts valve stem
Sounds like you need rights post a pic with the bad ones marked
In pic rockers in bottom row are upside down, in that pic you are choosing right hand rockers
When you look at your engine each rocker bolt has a left and right,left to left of bolt,right to right of bolt
