Rocker identification LH vs RH .......
Old Aug 24, 2013 | 10:54 PM
nuclearw's Avatar
Default Rocker identification LH vs RH .......
Ok, need to order two rockers and gotta know which to order, I know there are 2 diff ones per cyl but cant find anywhere that clearly identifies which is which.
The ones I need, standing on the drivers side, staring at the rockers, they would be on the right of the bolts..
this would be with the pushrods on the side of the rocker facing away from you.
If you have a clear way of identifying them, that would be appreciated...
Thanks!
Old Aug 25, 2013 | 08:21 AM
Identification groove - should be visible if you look closely, slide spring away, etc.
Left
Right
Old Aug 25, 2013 | 08:29 AM
TOM R's Avatar
yeah I screwed this up and ended up with a right I don't need
Super easy each cylinder has a left and right look at cylinder left of bolt is left rocker right of bolt is right rocker difference is offset of rocker tip where it contacts valve stem
Sounds like you need rights post a pic with the bad ones marked
Old Aug 25, 2013 | 08:38 AM
pix of them all
Old Aug 25, 2013 | 10:11 PM
nuclearw's Avatar
pix of them all
In your pic, bottom row counting from the left
would be #3 and #5 both on the left-side of the posts
Old Aug 26, 2013 | 08:53 AM
TOM R's Avatar
In pic rockers in bottom row are upside down, in that pic you are choosing right hand rockers
When you look at your engine each rocker bolt has a left and right,left to left of bolt,right to right of bolt
Old Aug 31, 2013 | 03:29 PM
nuclearw's Avatar
Got the rockers in today, they are in fact the RH, better just to make sure, and I hope this thread can help someone else in the future.
Punter
Defender
Jul 6, 2022 04:57 AM
cst756
Nov 4, 2009 08:51 PM
Discover' Carolina
Feb 22, 2009 07:57 PM
mburnett
Apr 8, 2008 08:59 PM
bigugly82
Dec 22, 2007 02:49 PM
