Rocker shaft oil
Old Jul 4, 2020 | 08:05 PM
jjh221's Avatar
I will try to test pressure tomorrow and have some research I remember there is an oil by pass valve under the filter. I will check this first. Could it be stuck?
Old Jul 5, 2020 | 09:46 PM
Banzai Jimmy's Avatar
Shouldn't matter. That bypass is for the filter, not anything else in the engine.
Old Jul 6, 2020 | 12:38 AM
hrhoward's Avatar
When I tore into mine, the rockers were very difficult to get off the shaft.
The shafts, pedestals, and rockers were all pretty-much clogged with sludge.
Had to use a wee drill bit on the rocker ports.
Took apart the tappets and cleaned as well.
Everything was nasty. In all honesty, it's hard to believe it was running at all.
Old Jul 6, 2020 | 10:30 AM
jjh221's Avatar
ok. Just checked pressure its 36-40 @ 2500rpm. About same at idle
Running valvoline syn. 10w-40
Old Jul 6, 2020 | 10:53 AM
hrhoward's Avatar
There are some pictures of what I cleaned out the shafts, pillars, and rockers in my album.
Dirty Rockers and Such.
Old Jul 6, 2020 | 11:16 AM
jjh221's Avatar
https://streamable.com/75r25p
https://streamable.com/mmvi30
Old Jul 6, 2020 | 11:18 AM
jjh221's Avatar
ok thanks I'll try and clean those more. I cant Most of the rockers off because the pedestal are stuck on the shaft. M
Old Jul 6, 2020 | 11:27 AM
jjh221's Avatar
Old Jul 6, 2020 | 11:39 AM
hrhoward's Avatar
My pedestals were stuck as well. Used a small chunk of oak and a hammer to tap them off, cleaning the shaft ahead of them. Took a while, but eventually they came off. Remember what goes where.
Old Jul 6, 2020 | 12:16 PM
jjh221's Avatar
Think I figured it out the shaft may notched wrong? The holes seem to be facing down.
