Rocker shaft oil
Old Jul 6, 2020 | 12:34 PM
  #21
jjh221's Avatar
Old Jul 6, 2020 | 11:34 PM
  #22
ihscouts's Avatar
The notch at the end of the shaft is facing you on the right head, back side of head on left shaft. As far as running synthetic these engines where built before synthetic tolerances, they like regular dino oil and the heavier the happier they are. Your cold oil pressure is below spec, should be a tick under 40psi at 2500 rpm engine at temp.
Old Jul 7, 2020 | 08:35 AM
  #23
jjh221's Avatar
I put her back together. The book says the notch should be up so the oil holes face up. Which oil line the rocker oil ports and the shafts much closer but I cant find much info. I get 40-41 psi warm at 2500. Ima just send it
98VARover
Sep 12, 2018 07:50 PM
The_OGCJR
Sep 29, 2016 08:41 AM
acamato
Jul 27, 2013 02:10 PM
tcar
Feb 27, 2012 03:08 PM
David Kadasia
Apr 27, 2010 02:24 PM
