Running Rich, LTFT -18?!
Old Apr 6, 2013 | 11:48 PM
LRchick's Avatar
Default Running Rich, LTFT -18?!
I was monitoring my truck tonight and realized the long term fuel trim (LFTF) was -18 (+/- 1.5) regularly even once the truck was heated up. Is this how Rovers run or a bad O2 sensor?
Do people usually tune this out? Should I worry about this? It just seems to be wasting fuel if this is how it normally runs.
Thanks!
Old Apr 7, 2013 | 08:12 AM
You do not tune out a possible 02 fault. How many miles on the truck, have the 02's ever been replaced and have you compared the readings from Banks 1 and 2?
Old Apr 7, 2013 | 10:57 AM
Here's the book on the GEMS computer, explains it in more depth than the basic RAVE. Values should not be "static", they should change. I got almost 17 mpg last week on flat ground with my 97. Fuel economy with a Rover is measured by.....
File Type: pdf
stephenmcdermott
Nov 19, 2006 09:09 PM
stephenmcdermott
Nov 19, 2006 05:57 PM
disco boy
Sep 18, 2006 10:30 AM
dmonares
Aug 27, 2006 01:47 PM
Tibbs
Oct 2, 2005 12:08 AM
