Scraping sound on front right wheel
Old Feb 9, 2012 | 05:37 AM
  #21
slanginsanjuan's Avatar
Originally Posted by honda50r
Slang, you totally revamped your rear cargo compartment. Grinding, welds, prep, etc. Wheel bearings should be cake for you.
Really? Thanks for the vote. Maybe I can do this. Need to research tools and get me couple of jacks. I'm on it.
I can't weld by the way. I'd love to learn how.
Old Feb 9, 2012 | 07:02 AM
  #22
Do one side 100% at a time, so you can compare to other side if a problem.
Old Feb 10, 2012 | 06:49 AM
  #23
YEs I would do that...one at a time. I need to figure out what tools I need including a jack and stands. I don't have much. I think Calebbo outlined it..ill go look.
Old Feb 10, 2012 | 05:43 PM
  #24
A good sized crescent adjustable wrench is a start, and some smaller pliers. A hammer and chisel to bend the fold over washer out of the way.
Old Feb 11, 2012 | 09:02 PM
  #25
Danny Lee 97 Disco's Avatar
I bought one of the large adapters made to fit the lock nuts, but with those you cannot use a torque wrench when putting it back together.
There are several good write-ups and a video or two on utube as well. And you need the grease for packing the wheel bearings and if you are putting in new bearings, you need something to beat the old races out to put the new races in. According to Tom, you never want to leave the old cones in there with new bearings.
He also advocates the double lipped seals over the stock ones.
Old Feb 11, 2012 | 09:25 PM
  #26
Amen on the no old bearing parts, will wear the new ones out pronto. Use a brass drift pin and / or old cones to hammer things out, brass does not mar surfaces as easily.
Old Feb 11, 2012 | 09:30 PM
  #27
I tried to find a brass drift. The only lead I got was they were listed as tools for gunsmiths. I wanted to buy one and could not find any anywhere. Fortunately, my bearings were all good, so I just repacked them.
I also replaced all my rotors and pads at that time and two calipers (rear).
chris006
Apr 2, 2011 04:38 PM
adriennereynolds
Freelander
Jan 18, 2011 06:09 PM
TheUninformedOwner
Apr 16, 2009 02:46 PM
TheUninformedOwner
Freelander
Mar 26, 2009 11:39 AM
