Seafoam induction on Discovery series 1
Old 10-07-2013, 10:19 PM
abran's Avatar
Default Seafoam induction on Discovery series 1
Does anyone have a picture or instruction on where the vacumm intake is on the D1 that I hook the clear hose to? I want to do the treatment but can't find a definitive answer.
Thanks.
Old 10-08-2013, 05:52 AM
Stand on the side of truck with battery. Look at intake. See rubber hose from intake to fitting on right side valve cover. Use that hose, suck 1/3 - 1/2 can into the intake. Let sit a few minutes. Crank up and drive, be prepared for large cloud. Goes away in a few minutes. Do not do this inside garage. Do not do this if neighbors are prone to call 911.
What goes along with this is using carb cleaner to wash out your PCV system (come from both valve covers), and clean the throttle body buttery fly valve, and remove and clean the IACV. Buy special made for MAF spray and clean MAF when stone cold and truck has not been turned on for hours.
Old 10-08-2013, 01:54 PM
abran's Avatar
Thanks. Excuse my ignorance, What is IACV? Where is it?
Also, Where is the MAF?(I know it stands for Mass Air Flow sensor...I think)
Thank you,
Abran
Old 10-08-2013, 03:17 PM
Find air filter box. Work toward engine. Next big gizmo is the MAF, in series with the rubber hose. The Idle Air Control valve is bolted into the throttle body. It is the next sensor you come to. When removed, you will see it is a 200 step stepper motor with a cone shaped pintle end. This controls the vacuum leak at idle and the idle speed. Don't tinker with the end, just spray it.
Old 10-09-2013, 10:43 AM
abran's Avatar
Perfect. Thanks again.
Old 11-09-2013, 04:57 PM
BHamms's Avatar
Ok so I decided to Seafoam my motor. Poured half the can into this hose. Let it sit for ten minutes, cranked her up. No smoke, what-so-ever. Did I pour into the wrong hose? Did I damage my motor?
Old 11-09-2013, 09:43 PM
abran's Avatar
Does that hose go into the intake manifold? It shoilild be into that cast martdl thing with your motor size on it.
Old 11-09-2013, 09:53 PM
BHamms's Avatar
Connects at the lower circle. Yes, the whole connection runs into the intake. Disconnected it to add the Seafoam
Old 11-09-2013, 09:58 PM
BHamms's Avatar
I'm thinking maybe I poured it into the wrong end of the hose.....
Old 11-10-2013, 05:12 AM
abran's Avatar
The seafoam is supposed to be "sucked" into the air intake, not poured. I haven't actually done it, so I just guessing based on what I've read. It sounds like instead of the seafoam going into the combustion chamber it has gone into your oil system/crankcase. Definitely explains why there is no smoke.
With my limited knowledge I would suggest you do and oil flush and change. I say flush only because I have been sold that by the local lube and tune, but not sure what that actually entails.
There might be more you can do, hopefully one of the senior members will chime in.
Good luck, I bet you wish you had never heard of seafoam at this point.
Quick Reply: Seafoam induction on Discovery series 1
