shifter
Old Aug 10, 2015 | 03:33 PM
ryderbul101's Avatar
5th Gear
Default shifter
hello, I am new ,,have had my 1994 disco for the 3 years. main issue cannot get it to shift into hi or low range. not an issue to lock diff. any ideas thank you ...also any clubs in North West Arkansas
Old Aug 15, 2015 | 11:28 AM
june82000's Avatar
Check the manual to see if there's an adjustment option for the shifter. Sorry, I don't know since I'm new to these and mine works for now.
Old Aug 17, 2015 | 08:05 AM
5th Gear
thanks for the response will ck.... thank you
Old Aug 17, 2015 | 02:37 PM
june82000's Avatar
It just so happens that I had to look at that part of my transmission over the weekend. Basically, if you remove the center console along with the rubber boot covering the gear selectors (you'll have to drill out the rivets) then you can see the mechanism for selecting hi and low range. There are adjustments. You can also vacuum underneath the console when you're in there.
moneypit37
Nov 27, 2006 02:20 AM
la gale
Oct 7, 2006 05:49 PM
jwmstang
Sep 25, 2006 11:15 AM
Music
Freelander
Aug 17, 2006 12:55 AM
BuckMontecristo
Jul 21, 2006 09:27 PM
