Stuck shifter
Old Sep 12, 2006 | 09:58 PM
jwmstang's Avatar
Default Stuck shifter
I have a 1998 LR Disco. I took it to get it washed at the car wash. After washing my LR it wouldn't go out of park. The shifter is stuck. Ever since I purchased it there has been a problem with the brake lights, they have constantly been as long as the car was rather the brakes were applied or not. I don't know if this might be part of the issue but they are completely out now. Any ideas???
Old Sep 12, 2006 | 10:10 PM
Default RE: Stuck shifter
You have a brake switch failing, it is located under the dash at the foot brake, around $28 and a 5 or 10 minute repair,
Good luck,
Mike
Old Sep 17, 2006 | 04:28 PM
jwmstang's Avatar
There is 2 switches on the brake pedal. One has a vac hose going to it. Is this the one you are talking about or is it the other one. If it is the other one any idea on what the other does and where I can find one. I was just going to replace both switches but I can't find the one with the vac line in it. This may be due to the fact that I don't know what it is or what it is called. Thank you
Old Sep 17, 2006 | 07:07 PM
The one with the hose is for the cruise control, you want to change the other one.
Mike
Old Sep 17, 2006 | 08:50 PM
jwmstang's Avatar
Thank you!
Old Sep 22, 2006 | 11:48 AM
jwmstang's Avatar
I finally got my switch in the mail yesterday and put it in today. I forgot to check the fuses first but now it still isn't working even with the switch. I checked the fuses and the 15Amp fuse for the brake lights was blown. I replaced it and started the disco and tried to get it out of park...nothing. I checked all the fuses and the same 15 Amp fuse was blown again. Any ideas what could be overloading the system?
Old Sep 22, 2006 | 12:02 PM
If you continue to blow fuses, you either have a short or the solonoid in the tranny is fried.
Mike
Old Sep 22, 2006 | 12:27 PM
jwmstang's Avatar
Where is that solonoid? Is that the actuator that I am finding at atlantic british? Thank you for your help!
Old Sep 25, 2006 | 11:15 AM
jwmstang's Avatar
I have taken the center console out looking for a short or anything unusual. I have found nothing. Where is the solonoid located? I can't seem to find it. Thank you.
Brad S1
Sep 19, 2022 03:25 PM
pinkytoe69
Aug 25, 2014 07:00 PM
ImQuattro
May 1, 2014 08:36 PM
mellyagaunce
May 18, 2009 08:08 PM
moneypit37
Nov 27, 2006 02:20 AM
