Shop-time Estimate
Old Sep 13, 2021 | 12:01 PM
disco96sd's Avatar
Default Shop-time Estimate
I might let my local Landy professor handle a job and wanted to see what you think might be a ballpark guesstimate on shop-time:
1) Drop oil pan - inspect / clean pickup tube / replace gasket
2) Replace oil pump / timing chain and gears / water pump
Thanks
Old Sep 13, 2021 | 01:37 PM
JohnZo's Avatar
I'll hazard a guess: 1. 2-3 hours. 2. Substantially more, say 6 - 10 hours. Somewhat dependent on how dirty it is. Only replacing the water pump will be a lot less. Changing the timing chain and gears won't gain much if the cam and lifters are worm out.
The front bolts of the pan are connected to the front cover, so it's good to plan your sequence.
Have you replaced your cam/lifters/rocker arms yet? Crank and rod bearings? The bearings can be changed with the pan off (will need to renew seals for the crank caps side bolts, and crucifix). To change the cam, the front cover will need to come off and the lifters removed. To change lifters and rocker arms, the valve covers and intake manifold need to come off. Have you heard about "scope growth"? Maybe depends on why you need to get the work done, what your budget is, and what work has been done previously. I hope this is helpful. Something to think about anyway...
Old Sep 14, 2021 | 12:42 AM
ononomos's Avatar
I would drain oil and drop the pan myself and take a look before I’d send it off to some other dude.
Old Sep 14, 2021 | 07:24 AM
disco96sd's Avatar
Thanks folks
just replaced manifold and valve cover gaskets along with new lifters - cam rocker arms push rods were in excellent condition
hoping not to need crank bearings but inspection will tell
timing chain is a 100K mile replace and I am nearly there and of course water pump at same time
Old Sep 15, 2021 | 11:33 AM
WaltNYC's Avatar
the labor times manual for the Defender is in the google drive. It is a good guide for these trucks since they are very similar, but not exactly the same.
Old Sep 15, 2021 | 12:08 PM
disco96sd's Avatar
thanks
blakslee720
Dec 11, 2019 10:01 AM
KingKoopa
Jan 28, 2017 09:52 AM
G150driver
Mar 7, 2015 09:10 AM
FlyingZebra34
May 15, 2013 05:43 PM
Osiris
Sep 13, 2011 01:48 PM
