Oil Pump
Old May 15, 2013 | 05:39 PM
FlyingZebra34's Avatar
Default Oil Pump
Mine is still ok but I want to go ahead and replace any needed parts as apart of my current overhaul. Is this rebuild kit any good or should I get something else??
Oil Pump Gear Kit W/Gaskets - Land Rover kits from Atlantic British
thank you
Old May 15, 2013 | 05:43 PM
That is the one, and you might consider a timing chain if you are going in there, plus with the oil pan off, clean pickup screen, and a new o ring or seal for the pickup tube and two dabs of locktite of the pickup tube bolts. Oil pan gasket.
A5scott
May 18, 2015 06:34 AM
Danobp
Jun 3, 2014 04:15 AM
eaglewing
Apr 16, 2011 11:06 AM
DooDer
Jan 12, 2010 10:46 PM
barranr
Jun 3, 2007 06:36 AM
