Short vs tall oil filter options- any downside?
Old Apr 30, 2018 | 03:34 PM
mirrajumper's Avatar
Default Short vs tall oil filter options- any downside?
Going through Disco mikes service list on the Trek. The local supplier had both a short Mobil 1 filter M1-204A and a taller WIX 51773. Logic states bigger filter is better- true in this case? They also listed Man 940/5 but out of stock. Rosella is at 14.99 a gallon- so stocked up for lots of disco love.
Old Apr 30, 2018 | 03:59 PM
FloridaRover's Avatar
I run the K&N 3001 "tall" filter on my D1's, but not sure how it compares in actual length
IIRC, The D2 is limited to the short filter because of the location above the panhard rod
Old Apr 30, 2018 | 05:20 PM
Default Filter height
will take a clearance measure tonight. Other than height- the casings, seals and specs are the same according to vendor.
Old Apr 30, 2018 | 10:01 PM
jvarnadoe's Avatar
I've used the following "tall" filters on my D1. These are about an inch taller than the stock filter at just over 5" in height. I have no way of judging the performance of their filtration capabilities, so I just use the Wix 51515 now since it's quite a bit less expensive and seems well constructed. I've had no issues with any of them.
K&N HP3001
Mobil 1 M1-301
Wix 51515
Old May 1, 2018 | 08:22 AM
According to some other threads, the taller filter can interfere with the steering damper if you’ve relocated it a la defender style. There is also some chat about 20 micron filtering vs 40 micron filtering specs.
Old May 1, 2018 | 08:05 PM
stillruns's Avatar
I run this one and have had no problems. Folks here recommended it.
https://www.napaonline.com/en/p/FIL1515
Ronio
Freelander
Feb 18, 2018 10:30 PM
mln01
Apr 4, 2015 02:46 PM
Alex_M
Mar 9, 2015 04:56 PM
HeaveBoston
Sep 27, 2014 11:38 PM
mcmwnc
May 7, 2013 10:16 PM
