should have replaced head gasket
Old Oct 30, 2010 | 05:41 PM
bantham1's Avatar
Default should have replaced head gasket
I recently replaced a leaking valley pan gasket a couple months ago. All is well until now I notice a coolant smell from the engine after a long trip. Sure enough head gaskets are leaking externally at the rear of the engine. I am tempted to try a stop leak product since this a slow leak but don't want to clog my radiator as I just had it rodded out. What do you think?
Old Oct 30, 2010 | 06:36 PM
Danny Lee 97 Disco's Avatar
Do you think it leaked as a result of something you did while changing the valley pan gasket or just coincidence?
Old Oct 30, 2010 | 06:43 PM
Stay away from the stop leak products unless you want even more problems.
Old Oct 30, 2010 | 06:55 PM
Spencerfitch's Avatar
stay away from stop leak. Just continue to watch temperature and fill coolant. Not ALL headgasket failures cause overheating.
Old Oct 30, 2010 | 07:24 PM
bantham1's Avatar
Probably just coincidence. I was going to add half a tube of alumaseal to see if it would help. It is not overheating now, I just have to watch the coolant level. This is an external leak as far as I know b/c my block tester detected no gases and it is running fine. Anybody used a tablespoon of black pepper?
Old Oct 30, 2010 | 08:02 PM
I really wouldn't use ANY LEAK STOP.
Old Oct 30, 2010 | 08:15 PM
bantham1's Avatar
Probably will not use a "stop leak." Did some research and GM apparently added "coolant tabs" to vehicles to prevent leak with no adverse side effects.
ctk111
Nov 20, 2012 02:23 PM
hotdog3030
May 17, 2012 04:35 PM
DiscoIIDrew
Feb 24, 2012 03:06 PM
01d2Jeff
Jan 30, 2012 10:18 AM
kylelind
Feb 24, 2011 07:35 AM
