Soft brakes after master cylinder replace/bleeding
Old 09-03-2019 | 12:59 PM
Zulu1's Avatar
4wd High
Smile Soft brakes after master cylinder replace/bleeding
First, let me say how grateful I am for this forum and those who share their Disco wisdom!
I have a 97 Disco 1 and it was sitting for a year. It held up pretty well but the brakes are now very soft. There is no noticeable loss of fluid. We tried a full bleed and that didn't fix it so we replaced the master cylinder and bled again. There are points where I can feel them tighten up.....only to go soft again. It feels like a leak but no fluid loss.
I'd appreciate any advice.
Old 09-03-2019 | 01:02 PM
WaltNYC's Avatar
what brand of MC did you put in?
Old 09-03-2019 | 01:40 PM
Zulu1's Avatar
4wd High
The master cylinder was made by Brake Best from O'Reilly's. I didn't think that it was a part that needed to be genuine OEM.
Old 09-05-2019 | 02:41 PM
ihscouts's Avatar
We've a long history of failed aftermarket MC"s here. They either internally leak or lock up the brakes hard.
Old 09-05-2019 | 05:24 PM
jvarnadoe's Avatar
I replaced mine back in January with a master cylinder from Atlantic British. It's now been on the vehicle for 12k miles and I've had no issues.
The LR part number is STC1284 and AB sent a TRW - part number PML218.
Zulu1 (10-01-2019)
Old 09-05-2019 | 06:02 PM
ihscouts's Avatar
If you notice in the bottom right corner of the sticker it says....."Lucas". It's as OEM as can be. Under it in white print is says "Sign of the Devil". Aint a cheap part fo sho.
Zulu1 (10-01-2019)
Hoots
10-30-2016 04:55 PM
discoken
03-07-2014 03:29 PM
Chapman Conti
11-12-2012 08:31 PM
RamblingMan
12-10-2009 06:34 PM
Shaymer
11-18-2008 12:42 PM
Quick Reply: Soft brakes after master cylinder replace/bleeding
