Speedometer mystery...
Old Jul 14, 2014 | 12:04 AM
Kalev's Avatar
Default Speedometer mystery...
I know millions of people have posted about this problem, and I hate to be one more person, but...I need some help. I can only hope that I can clearly explain this, issue/question.
I did some experimenting...
I have several Discoveries, all with LT265/75R16 and with the Transducer Speed Sensor AMR1253, and sadly, all of the speedometers are "off." BUT, one of the Discoveries speedometers is perfectly accurate (and it has the LT265/75R16), the key difference is that it has Transducer Speed Sensor YBE 100540.
The question is, I just bought another Rover that has been regeared and also has LT265/75R16, now, when I bought it, it had the Transducer Speed Sensor AMR1253 and the speedometer was extremely off, so I switched it to the YBE100540, and now it is only within 5 MPH, which must be because it has been re-geared... so, what is the difference between the YBE100540 and the AMR1253?
Also, does a solution exist to fix the speedometer on a Disco with larger tires and that has been re-geared?
Thank you!
Kalev
Old Jul 14, 2014 | 12:11 AM
fishEH's Avatar
Gps. :d
Old Jul 14, 2014 | 12:36 AM
Kalev's Avatar
Originally Posted by fishEH
Gps. :d
I'm starting to agree, GPS is about to be my new best friend... Thank you for your reply.
Old Jul 14, 2014 | 04:07 PM
ihscouts's Avatar
The YBE100540 is for a Defender with 4.0L. Defenders wear 265's as stock tire size.
sandnsable
Nov 24, 2011 09:32 PM
Phototone
May 3, 2008 12:15 PM
morfa
Feb 16, 2007 11:19 AM
The Mighty Finn
Jun 20, 2006 01:46 AM
lbvbroker
Mar 4, 2006 01:28 PM
