Speedometer problems
Old Jun 15, 2006 | 07:40 AM
The Mighty Finn's Avatar
Default Speedometer problems
Just had a problem develop on my Disco.
Driving yesterday (in very warm weather) and the speedo started to twitch and then dropped to zero.
It came back for a few miles, but for most of my driving yesterday it was dead.
Worked for a few miles this morning then dropped to zero again.
Is this a fault anyone else has come across - is it easy to fix?
(I'm an electronics engineer, but useless under a bonnet!)
A while back I had a similar problem with the tacho and with help from this forum was able to fix it.
Hopefully, I can do the same again...
Thanks in advance.
Steve
Old Jun 17, 2006 | 12:22 AM
Landdaddy's Avatar
Default RE: Speedometer problems
I would think that it might be the speed censer, but that is a guess, if I am not mistaken and I hope I am not, you might want to check to see if the wire that leads into your transmission is intack, or loose, last year I had the same problem and I climbed under the rover and just pulled on the wire just a bit and it has worked ever since. However, here is the problem, I don't know for sure if that was the cause of the problem. but it worked what ever I did under there.
good luck
Old Jun 20, 2006 | 01:46 AM
Bait's Avatar
Steve, Do a search. VSS!!
sandnsable
Nov 24, 2011 09:32 PM
AK Rover
Sep 11, 2008 09:10 AM
Phototone
May 3, 2008 12:15 PM
morfa
Feb 16, 2007 11:19 AM
lbvbroker
Mar 4, 2006 01:28 PM
