spider
Old Mar 19, 2012 | 08:58 PM
Higgs Boson's Avatar
What issue are you wanting to bypass the alarm to get out of? The ECU and AS10 are co-dependent, you would be better off not trying to separate them.
Old Jun 15, 2013 | 05:28 PM
bdie53L's Avatar
3rd Gear
Hey everyone. I'm glad to find out that this is somewhat of a common problem. I have been yanking out my eyelashes trying to figure out this quandry with my As10 module. I am a first time LR owner. I bought this car as a project car and what a project it has become. I am a bit of a novice when it comes to my truck but I'm the type that has to learn hands on. That being said I am afraid I have locked up the system fidgetting with it. I bought the vehicle used and equipped with an aftermarket security system installed alongside the factory one. I believe they work in tandem I however do not have the original fob only my AM one. I would normally be able to arm/disarm the factory alarm by using the driver side door lock however it has since broken and turns freely. So Know must allow the truck to remain unlocked but I could still arm the aftermarket intruder alert. THis is where it gets tricky. I started to have weak starts about 2 months ago which then in turn became no start. At first I believed it to be a faulty battery so I Charged overnight then replaced only to find that it would crank but not turn over. The led on my dash began doing weird things(I.e blinking flashing solid) while simultaneous clicking noises under the dash which is what drew my attention to the as10. I have located the driverside door switch with the face off of the door to manually activate the door lock switch to no avail. No arm or disarm. Also I had noticednproir to this debaccle
Old Jun 15, 2013 | 05:35 PM
bdie53L's Avatar
3rd Gear
That when I would inadvertantly press the door locks it would automatically kick back and unlock itself. It no longer does that. Also I counted the clicks when its going haywire and it will click 10 X's before it stops. And at times it will only allow me to arm and not allownme to disarm. If this is making any sense to anyone out there please advise it will be greatly appreciated. I simply fell in love with my truck at first sight. Its now developing somewhat of a love hate relationship.
Old Jun 17, 2013 | 07:42 AM
gprtech's Avatar
You can't.
If you can get one of the advanced scantools that handle the Disco, you can disable the features.
Or you can go to a Dealer.
Old Sep 15, 2013 | 10:09 AM
marjac's Avatar
Is your vehicle made for the North American Spec market? The NAS and non-NAS is different. What page in the RAVE electrical manual do you reference?
Can you tell me based on my vin number prefix if I have the spider control SALJY?
My 96 D1 has fallen and cannot get up.
jasonpope
Aug 31, 2009 05:18 PM
sikegan
Jan 5, 2009 12:31 PM
crownaviation
Sep 10, 2007 11:34 PM
suveer
Apr 26, 2007 05:26 AM
BMWLR
Sep 7, 2006 03:21 PM
