Spring Questions
Old Jan 10, 2012 | 06:34 PM
llPANCHOll's Avatar
Default Spring Questions
So I've known the shocks have needed to be replaced for a while, but now its bordering on dangerous, the truck has 85k miles on it now, so I have a new set of Bilstein's.
46mm Monotube Shock Absorber
Part Number: 24-188302
Setting: 4600 Series
Position: Rear
Descriptor: Setting: 4600 Series
Old Part Number: 24-002530;F4-B46-0253-M0
Part Number: 24-188296
Position: Front
Old Part Number: F4-B46-0243-M0
36mm Monotube Steering Damper
Part Number: 24-188272
Position: Front
Old Part Number: F4-B36-0245-M0
I do not use the truck off road, and I do not have any desire to lift the truck. My mother has a difficult time getting in the truck as it is now. I do however want the truck to ride nice.
I realize that the springs compress over time, but do they wear out as well? Do I need to replace the springs with the shocks? What are your recomendations?
Old Jan 10, 2012 | 09:30 PM
My springs are original and I have a ARB winch bumper, roof rack and ladder and Gabriel Ultra shocks, 210,000 miles and she rides fine.
I do offroad, no rock crawling though.
Just replace your shocks and be done, unless you have a broken spring I would not worry about it.
Yes my truck sits lower than when new, but it does not bottom out over bumps or while offroading and it still wont fit in a parking ramp.
Old Jan 10, 2012 | 09:59 PM
jafir's Avatar
My D2 with ARB bumper and winch drives noticeably different, and sits just a little lower in front with stock springs. I just haven't made myself get something more heavy duty. I'm pretty sure that when I do, that will be the last time it fits in the garage.
Old Jan 12, 2012 | 01:34 PM
DiscoBlanco's Avatar
Coil springs are quite resilient. They can last almost forever.
Old Jan 12, 2012 | 03:20 PM
geek_IM's Avatar
Your shocks have nothing to do with ride height, that is solely controlled by your springs. The only thing that can happen over time is the truck will develop a "listing to starboard" kind of look, as all four springs were originally (over)engineered with differing spring rates for each individual spring, supposedly to help the truck remain true-level, and can sag at differing rates over time. If the truck is at an acceptable height, and you don't bottom out over bumps you are good to go. If you do decide to replace the springs, DAP has a pretty cheap set of soft springs, but any new springs will most likely raise your truck 2"+.
Old Jan 12, 2012 | 05:55 PM
coolbeans's Avatar
That is good to know, as that is exactly what mine is doing.. we have serious "crowned roads" here, so driving by myself, its not bad, but with a passenger, it really leans! Thanks for the info!
Old Jan 13, 2012 | 11:34 AM
Josh.0's Avatar
I have Old Man Emu lift springs on my Disco 1 and the ride is great.
Old Jan 16, 2012 | 06:41 PM
llPANCHOll's Avatar
I have them installed now, and its quite the improvement. Thanks for the input guys.
XxRoverAllOverxX
Dec 14, 2010 05:07 PM
jdg52
Nov 19, 2010 10:42 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
avking
Feb 18, 2009 05:10 PM
mdvickst
Mar 6, 2007 01:30 PM
